BenchTec
Go Back   BenchTec > Members area > Members Discussion
Reply
Thread Tools Display Modes
Old 20-03-2009, 02:50 PM   #1
Johnny Bravo
Bench team-Hwbot Guru-hardware Master
Johnny Bravo's Avatar
Johnny Bravo is on a distinguished road
Default Official BT-UK Sparkle 9500GT Competition thread
As things have been made more official I left it was time for us to have an official thread on the competition
The contest
The contest consists of an old benchmark called Nature in 3dMark01. This benchmark has been chosen for the fact that only GPU-dependent. In short this means that it does not matter what system you used for the benchmark, because the result will always be the same (in theory).
Prizes
Yes! There are prizes too
1st. 200 euro
2nd 130 euro
3th. 85 euro
These will be in the form of a voucher to dollarshops.eu so you can buy new hardware
Add your scores
Scores are processed in a central system, which can be found at overclocking-holland.nl/contest. Once you’ve all been registered you’ll be provided with the login information. When submitting you will be required to upload the following information :
  • Score in frames per second
  • Core clock, in Megahertz.
  • Shader clock in Megahertz
  • GDDR clock in Megahertz
  • VGPU in milli Volt (if you don't have a voltmeter you can just quote the stock voltage)
  • VGDDR in milli Volt (again just quote the stock voltages)
  • Method of Cooling used
  • A valid screenshot which will be uploaded onto the server. The guidelines for creating a screenshot are given in the rules below.
Rules
To ensure a fair competition, there will be a few rules that have to be obeyed. The rules used will be the same as those used on hwbot.org. These rules are very clear about what is and what is NOT allowed.
Use the standard settings in 3DMark
Let your screenshot clearly see the following aspects:
  • 3DMark score
  • 3DMark settings
  • CPU clock speeds in CPU-Z (fully visible)
  • GPU clock speeds in GPU-Z or RivaTuner for clock speeds (fully visible)
  • Full taskbar, including clock and the icons next to the clock shown. (Set "hide inactive icons" so OFF)
  • Notepad on screen with username
  • NO Watermarks and screenshot must be full screen size (no cropping)
  • PCI-E Frequency is to be limited to 115MHz
  • The following settings in the "details" screen 3dmark:
  • 3DMark Version should be 330
  • Display, with underlying options
  • Options, with underlying data
  • Results with fps for nature
Please note that when necessary you might be asked to replicate the score on location for validation....
Example Screen shot: http://img91.imageshack.us/img91/333/validation.jpg
Prohibited Hardware
None, except obviously using only the supplied 9500GT.
Prohibited Tweaks
  • NO Mipmap tweaking
  • Any software or human action that would affect the benchmark or alter the benchmark score resulting in a false result
  • Wire Frame hacks, software or a driver that ensures that the benchmark is not properly completed.
  • Only RivaTuner can be used for tweaking/adjustment of gpu clocks, including D3D Overider. Other tools like Nvhardpage, Nhancer etc. are not allowed. Simply put, if you can do it in rivatuner it's allowed
In case of doubt the score will be removed from the score list and the user will be asked for clarification. Be sure that your screenshots are in accordance with the rules and save your screenshots. There are no backups of the scores made on the server!
If the competition organiser contacts you about any tweaks you have you, you must be able to answer with an detailed description about the used tweaks. No cooperation means removal from the contest!
Competition deadline
To ensure that there is no disagreement on the deadline of the competition, we have a date for which all his or her overclocking results must be posted.
The overclocking competition is up to 31/05/2009 24:00 (they are one hour ahead so for us that's 11pm!!!!)
Our Team
  • Johnny Bravo
  • scooter.jay
  • EvOcarlos
  • SoddemFX
  • vento1
  • Dualist
  • r1ch
  • Nathanial
  • Starbuck
  • Jabski
The Card
Technical specs Sparkle 9500 GT
Model number : SF-PX95GT512U2-HP Passive
Graphics Processing : NVIDIA GeForce 9500GT
Core Clock : 550MHz
Memory Clock : 800 MHz
Memory Type : 512MB DDR2
Memory Interface : 128-Bit
Shader Clock : 1350 MHz
Bus Type : PCI-Express 2.0
RAMDAC : 400 MHz
Some Photos from the Organizers website:
Official Vmods
I chose to take the read points from the inductor make sure you measure from the correct leg!
Slightly Less Official Chat
The cards are DDR2 based and look to be memory bound score wise. Unfortunately its Qimonda memory which is basically the worse kind of memory to try and overclock Our best option is to redo the vddr mod so that we can vary the voltage both up and down as my previous experience with Qimonda suggested that it's very sensitive to voltage changes and doesn't like high volts.
Some of the Dutch contestants have discovered that upping the PCI-E frequency allows for improved overclocks on the memory and the GPU. We can do our on testing to see about this but we're looking at approximately 115-120MHz atm for the sweet spot
The GPU power circuitry features over current protection (OCP) that is based on the Rds(on) resistance on the lower MOSFET. Wit the current MOSFETs on the card the OCP limit is approximately 30Amps. We can increase this limit by changing out this MOSFET for one with a lower Rds resistance or Tom (SoddomFX) has suggested we could piggyback an additional MOSFET in parallel which will also reduce the visible resistance across the drain-source. Of course This will only be necessary if there is any real gains to overclocking the GPU core...
__________________
Johnny Bravo is offline   Reply With Quote
Old 20-03-2009, 03:07 PM   #2
Johnny Bravo
Scores Reference
  • Johnny Bravo - C1 Core
  • scooter.jay - B1 Core
  • EvOcarlos - B1 Core
  • SoddemFX -
  • vento1 - B1 Core
  • Dualist - C1 Core
  • r1ch - C1 Core
  • Nathanial - B1 Core
  • Starbuck - B1 Core
  • Jabski - B1 Core
Overall Competition Ranking
__________________
Old 05-04-2009, 09:09 PM   #3
Bolletje
Stock Air cooling
Bolletje's Avatar
Bolletje is on a distinguished road
Hi, I'm one of the people from overseas...
I was wondering, which revision do you guys have? Apparently Johnny has a A1, but the most people here in Holland got a C1.
And how does the stock cooler looks like? Like the one in the TS or like this one?
Bolletje is offline   Reply With Quote
Old 05-04-2009, 09:21 PM   #4
Dualist
Man called Unkle
Dualist's Avatar
Dualist is on a distinguished road
Yo dude and welcome
My heatsink is this one..
As for board revision I can't see anything like those numbers, got SFPX95 REV: D2.3 if that is any use.
__________________
Sry for my bad English
(I might be pissed)
נְפִילִים
Dualist is offline   Reply With Quote
Old 05-04-2009, 09:24 PM   #5
Johnny Bravo
Hi Bolletje; our cooler is the second on, the PCB version on the card however is the exact same
hope this helps
John
__________________
Old 05-04-2009, 09:34 PM   #6
Bolletje
Stock Air cooling
Bolletje's Avatar
Quote:
Originally Posted by Dualist View Post
Yo dude and welcome
Hi and thank you
Aha, ok. You can find the revision if you look @ GPU-z.
C1 + A1
Quote:
hope this helps
John
Oo, ok.
And what memchips do you guys have?
Nice forum btw
Old 05-04-2009, 09:36 PM   #7
Johnny Bravo
Nice forum btw
Thanks for the compliments on the forum Bolletje
The memory on the cards are Qimonda HYB18T512161CF–20
__________________
Old 05-04-2009, 09:52 PM   #8
Bolletje
Stock Air cooling
Bolletje's Avatar
Aha, so those are also the same.
Old 05-04-2009, 10:06 PM   #9
Snot_Aap
Stock Air cooling
Snot_Aap is on a distinguished road
Aha, so those are also the same. (56K warning)
That's a link to a restricted area of techzine.
But the cards are exactly the same, except for the revision of the core.
Snot_Aap is offline   Reply With Quote
Old 05-04-2009, 10:14 PM   #10
Bolletje
Stock Air cooling
Bolletje's Avatar
Quote:
Mwa, not restricted per se , but I editted it...
BTW, Johnny his card has a different BIOS...
But I think almost all the people here @ Benchtec will do a Vmod so that little difference isn't that important
@ Starbuck
Hi and thanks
Old 05-04-2009, 10:15 PM   #11
Starbuck
It's Not Balanced for Lean
Starbuck's Avatar
Starbuck is on a distinguished road
Welcome to BT Bolletje and Snot_Aap
__________________
Owning noobs since Windows 3.1
Quote:
Originally Posted by Raja View Post
Swiss: Opening birthday presents is just like making love to a beautiful woman. You pick her up and unwrap her clothes, have a bit of fun and when the novelty wears off look for something new..
Current toys:
W3540
5770(24/7 card)
5870(Forum Warz rig)
www.411overkill.com
Starbuck is offline   Reply With Quote
Old 05-04-2009, 10:18 PM   #12
Snot_Aap
Stock Air cooling
Quote:
Thank you.
I'm the organizer of the contest by the way.
Old 05-04-2009, 10:27 PM   #13
K404
Back to work
K404's Avatar
K404 is on a distinguished road
Welcome to Benchtec guys! Thanks for organising the competition snot! Hope its successful for you
How many entrants do you have so far?
__________________
Proudly using:
Crucial Ballistix DDR2 and Tracer DDR3
XSPC + Alphacool watercooling
Xigmatek aircooling.
Quote:
Originally Posted by margo baggins
it must be proper rubbish being a cpu in the hands of any the the big boys in this team.
Quote:
Originally Posted by JB
man u sure do make for some interesting stories!....that, Kenny, is total FUBAR
K404 is offline   Reply With Quote
Old 05-04-2009, 10:33 PM   #14
Bolletje
Stock Air cooling
Bolletje's Avatar
Quote:
Thank you
Hmm, I thought there were 85 from the Netherlands and you guys are with 10 or so. That makes ~95
@ below
Aha, ok
Old 05-04-2009, 10:33 PM   #15
Snot_Aap
Stock Air cooling
83 (in total), some guys subscribed but never bought a card.
For me it is succesful if you guy's are having fun. And myself as well ofcourse.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
